- Feb 6, 2017
- 96,276
- 11,920
- 113
Has that been removed ? Can't find to set power saving mode to turn on like at 15% or any other number.
That shouldn't be too much of a problem since, when the batery drops down to 40% you should either charge it or turn the phone off. Constantly dropping it down to 15%, with or without the battery saver coming into play, will kill the battery dead in a few months.
Install GSam Battery Monitor and set the low alarm to 39% (and pick an alarm), so you'll know as the battery drops out of 40%.
Pull your notification shade all the way down. Its located there.
I don't see where I can set it to come on at 25% automatic?
If you use Good Lock, you can set a routine to do that.
