Battery seems to be draining fast
kr4yzie
47
How does this look
Sent from my SAMSUNG-SGH-I747
The 4g lte using most of the batt based on the 2 signal bars. What is your brightness set at?
Have you tried turning of blue tooth, gps, wifi if not using it and 4g lte? And see if that helps.
Forgot to add, how are you using the phone?
I am sure somebody that knows a lot more about this phone will post with more options
Everything is off bluetooth wifi gps. I was messing around with widgets and texting that's it. Brightness is on manual and turned way down
Well, you've had the screen on for over an hour, and lost about 30% of battery. My experience has been that I can generally get between 3 and 4 hours of screen on time before my battery is dead, so I don't see anything wrong with your stats.
I usually keep the screen brightness at minimum unless I'm in lighting conditions that require it to be brighter, and I turn it back down when I'm done.
Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk 2
phalgal
