Battery % skips from ~40 to 20%
londonham
66
My battery always skips from the low 40s straight to 20%. I have the minimalistic battery app that tells me the percentage.
Does anyone else have this happen with their bionic? Is there anything I can do other than buy a new battery?
i had the same problem unfortunately buying new batteries was the only solution that worked. haven't had any issues since.
I've started having the same problem about 2 months ago. No idea why it started happening or how to fix it. Thankfully I'm not such a heavy user that my battery gets that low before the evening, although it would be nice if someone knew how to fix it (other than buying a new battery that is).
careerzoneacademy
