Battery temp 107 tonight...normal???
Praggles
167
8
I have noticed the past few nights since ICS install my phone has moments when it seems HOT! I have monitored using a battery app and recorded 104,105 and tonight during a spike it was 107..
Each time i disabled 4g and manually lowered screen brightness to no effect. Eventually i turn the phone off.
Tonight I took advice and factory reset...just spent 3 hrs resetting all screens. Real PIA! And i used backup...anyway I hope it helps...Is anyone's phone also spiking fevers after ICS?
Sent from my DROID RAZR using Android Central Forums
Mine was doing the same thing, after a factory reset all my problems went away, all of them
Thanks. That's reassuring! Phone seems fine now but its only been 4 hrs since FR.
Manufactures say 125? is high end but acceptable. My htc Rezounds get as high as 129? watching movies through mhl to TV. I have had my Rezound as high as 141? in car running GPS and on a call at the same time. Now that's to hot. 130? is considered overheat. 140? is unsafe, battery can turn into a run away (self heat until it catches fire or explode). Highest I have got Maxx to is 119?.
Ist full day after FR...no heat spike...apps better/updated all around...improved battery. Seems FR is cure for upgrade ills as others have said.
kiki2025
