Battery Tips and Tricks
jaybro0813
235
6
Are there any tips and tricks to improve the battery life on Rezound? I am new to REZ and looking for help.
Any tips would be appreciated
Biggest factor is display drain, so keeping the brightness down helps considerably. Don't activate Bluetooth unless necessary, and keeping system on CDMA-only (3G) if you don't need LTE speeds will add to battery life. Enjoy it -- it's a great phone.
Bump charge to train the battery. Google it.
Sent from my ADR6425LVW using Android Central Forums
You can turn off wifi/3G/4G and still get texts & make phone calls... (might be common knowledge now but it knocked my socks off when I first learned it)... if you work in an abysmal signal location, save your battery for when you get out of there.
I was out if town where I could sometimes get half a bar and occasional 1x data. The drain on the battery was immense. Dropping into airplane mode and enabling only WiFi if an access point was available gave a big advantage.
Oh, and always carry a charging cable, a wall USB AND A CLA charger.
Sitole Reshid
