Battery usage normal ?
Welcome to Android Central! Looks pretty normal to me. Battery life depends primarily on the size of your battery and how much the screen is on (since that is by far the biggest energy user). Some apps can really be a battery drain, but that amount of use by Chrome probably isn't too surprising if you've been doing a lot of web surfing.
What device do you have, and can you post your screen-on time?
Samsung Galaxy S4, and I will post the screen-on later as I fully charged my phone, but I think it was for about 4 hours.
4 hours of screen-on time isn't necessarily bad, depending on what else the phone's been doing. My Razr Maxx (with the monster battery) gets at best around 5.5 hours of total screen on time.
Hi....I get about 21 hours of battery on my GS4 I let it go down to 15% and charge it all night.....Try this and see if it helps..
It all depends on usage. You have a very similar battery life to mine. I am a power user, so this is all normal.
Sent from my GT-I9505 using Tapatalk 4
boone
