Battery Usage
Issemann
733
4
OK, I know there are a million posts regarding battery life for the Finch, but I've searched them all and couldn't find anything related to actual usage.
Is there an app/utility/anything available which will actually tell you what's eating up your battery? In other words, should I remove the Facebook widget from my home page? Should I get rid of my live wallpaper? Etc.
yea, go to settings>about phone>battery>click on battery use and it tells you what is using your battery. :)
Reactions: petrosil
..... "Finch"?
Yes, I've seen that screen and clicked on the Android System bar to see the details. But they're very high level. It only shows totals and a list of the processes.
What I'd really like to see is which process used the most battery, or the most CPU, etc.
There are a couple I know of in the market, Spare Parts, and BatteryHistory. I use Spare Parts, and it gives a much more detailed breakdown in battery consumption than the stock app.
Sent from my ADR6300 using Tapatalk
Winnie
