Battery Usage
yscty
64
I have 11hrs 26 min on my battery now, I'm at 24% battery life remaining. But what stumps me is it shows my SCREEN is taking up 52%.....Does this seem excessive? Wi-Fi, Google Services, Even Facebook, etc..... Are all under 9%
I find it odd the screen is taking up so much. Any ideas?
That's perfectly natural. The screen, when being used, does use up battery easily. What's your Screen-on time?
Well, I don't think that's excessive rather than I would say you are getting perfect battery life ! Screen should be taking 52% of the battery as it's the part of the device that eats up most of the battery if you think its a problem the do one thing remove the screen from your device and I am sure now your device battery will last more than a month !
I didn't look at that, I will check that out tonight as I'm on a full charge this a.m.
waqar53
