- May 18, 2010
- 101
- 0
- 0
I bought the extra 2 batteries with the wall charger about 8 months ago. It has served me well, but at least one is "going" and I need to get more. It's been $10 of the best dollars ever spent on the phone
With 2.3 update, it is wreaking inconsistent havoc with even the OEM battery when charged via the cable..
If I order some extended batteries, does anyone here know if they will fit the same wall charger used for the standard battery size? I would think they have the same makeup and are just "doubled" in size, but I figured someone here would know for sure.
Thanks.
Thanks.
