Battery......
rnich120
159
8
A lot of people are stating that the battery doesnt last the whole day with normal usage and because of that have to carry a charger about with them.
I'm no different at times.
So what do you do in order to keep your battery with juice to last you through out the day.
Me personally, I have the screen turned down to minimum and then have the emails on smart sync during the peak time (although I might change this to see what effect this)
I dont have sounds on most of the time.
Its connected to charger most of the day and wifi....
So what do you guys do....I think we need to share tips and any apps and ideas.
Thanks
I don't use it when i'm at work ;)
Unless you're pounding it all day it'll be fine. If you pound pretty much any Android phone all day it'll run flat.
If you dont actually need to use it but dont want to turn it off I know airplane mode is a big help. Also, get rid of widgets and apps that run in the background.
Same things as any Android phone:
1. Avoid Live Wallpapers.
2. Switching off 3G/4G
3. Switching auto-updates
4. Lower brightness.
5. Avoid surfing *cough Flash Sites at 5 am in the morning
opegamani
