Battery %.
Captian4Phones
98
Did HTC implement a stock battery percentage indicator for the status bar? I pretty much despise all the ones you can download from the play store.
Sent from Razorback Country.
I don't believe so. Why don't you try BatteryMix, from the Market? I think that you'll like it as much as i do.:)
Isn't the icon of the battery outline with the green interior the same thing as battery percentage? I don't know if the other apps provide a more realistic evaluation of battery life. The life of the battery is highly non-linear. Looking at the stock icon or going to settings to see that you have 48% battery left only gives you a warm-fuzzy. I've finally learned that having something like 22% remaining is next to nothing in reality!!
Kurt
I use Battery Widget on my homescreen. Doesn't go in the status bar though. Agree that battery life is non linear!
Sent from my HTC PH39100 using Android Central Forums
Battery Indicator/Battery Indicator Pro is an amazing app. Try it out in the Store and if you love the features, buy the upgrade, you won't be disappointed.:cool:
kiki2025
