battery
nextjeter2
111
4
Ok i just got a droid and have a iphone and the battery life seems horrible. I updated to 2. 2 The day i got it so im not sure if that is the caus. Compared to my iphone 4 it is pretty bad.. is there anyway to check if my battery usage is normal. On the iphone you could go to usage and see how long its been used and match that up to what your supposed to get anything liket that on android
Are you using GPS, bluetooth, full bright screen, etc all the time? Download battery time lite, it will show you where your power is going, but turn off all the utilities you're not using first.
Sent from my Droid
No need to download anything, you can see whats using the battery in the settings menu.
piikea
