Battery
gregorygamebeat
I have the SGH-T679 Galaxy Exhibit 4G, i've had this phone for 2 years now but today something odd happened i wake up to find my phone is not working anymore, i hadn't downloaded an app or anything or done something to the battery lately, NOTHING. i said it might of been my battery was discharged so i plug it in, i come back to see the phone not turning on....this was a shocker considering the phone hasn't been messed with so i tried hitting the power button while plugged and charging it shows an icon of a battery and a little alert sign next to it, am not sure what this means so i'd figured i'd asked you guys, can anyone help? :'(
Welcome to the forums.
My guess is battery failure. Could you have it tested or try another?
It is mostly likely a battery failure and I would only charge it with supervision because it is much more possible to cause a fire now. I go to a local flee market and can find a dealer with a spare battery from a used phone to test with. Twice now he has also sold me a new battery.
The first hour or so of charging a totally dead (as dead as you can get a lithium ion battery, which isn't actually totally dead) doesn't even give it enough charge to die when you try to turn the phone on. Leave the charger plugged in for 24 hours - without trying to turn the phone on - and see if it comes back.
To get the maximum life between battery changes, you charge the battery when t's at 40% to 60% discharged. To get maximum life between charges, you discharge the battery almost all the way - but that GREATLY shortens the life of the battery. If you've been doing it that way - discharging almost all the way before recharging - 2 years is a long time for the battery to keep running. You should get between 100 and (if you're very lucky) 250 charges that way. That's a year or less for most people. If you recharge at about 50%, you can get well over 1,000 charges. So you're probably due for a battery replacement.
It's a balancing act. Due to physics and chemistry, you can't get both long battery life and deep discharge from a lithium battery, but that's the highest density power source we have now, so it's what's used in phones. (A lead acid battery would be much better - but do you really want to carry a 10 pound battery around to power your phone? Even a gel cell lasts longer when deep discharged, but it's not that much lighter.)
We're going to have to wait for powdered silicon anodes before we see any major improvement in cellphone batteries (unless someone is working on something I haven't heard about yet), but that's years in the future.
(And it's one reason I won't buy a phone with a non-replaceable battery. I've spent years repairing phones, so I could replace the battery, but I'm getting too old, my hands aren't that steady and my eyes aren't that good, so it's a lot easier to just pop the old one out and push a new one in.)
pcjordanellis
