battey charging battery charging ..... what next !?!?
ossamoha
15
I have note 3 sm-n900 ( 3g version)
when i charge it and it reach 100% doesnt give full charged as other phones ??!
it gives charging and for more than 2 hours still same message ,,,, charging charging ,,,, what next ? !!?! ?!
What's happening is that your phone is charged to 100% and it's trickle charging keeping it charged at 100%. Your phone will say 100% charged but charging. It's normal so don't worry about it!
but wat i no is that every phone gives that is full charged and stop charging ???
Because Samsung phones (GS4 and Note 3) trickle charge after charging to 100% if left on. See, your phone uses background data to keep things up to date and that uses battery. So instead of charging to 100% and stop charging to run down the battery....it trickle charges once it reaches 100% to keep your phone charged at 100%. That's why your seeing 100% but it says charging. Nothing to worry about! :)
But battery sign appears 100% charge remove the the charger to save power.
Sent from my SM-N9005 using Tapatalk
No need to remove charger. I mean you can if you wish, but I charge my phone overnight and leave it plugged in all night. Won't hurt phone and keeps phone at 100% when I leave for work in the morning.
I've seen this debate going in several areas now about weather or not to leave your phone on the charger after fully charged. I'd just like to add
My evo LTE I bought on release so it's getting older. It doesn't get as much attention now that I have my One so it spends a lot of time sitting on the charger. Well yesterday I used it because I'm having troubles with my One and I got 4.5hrs screen on time and plugged in with 20% remaining battery.
I leave all my phone charging unless I'm using them and have never had any ill effects
Sent from my HTCONE using AC Forums mobile app
When I reach 100%, it tells me to unplug the charger. It has always done this since day one.
Sent from my SM-N900W8 using AC Forums mobile app
for me it is 100% but continues to say charging ,,, no msg to remove charger and fully charged
Then there must be problem. U should receive notification to unplug charger.
I have never seen a message about unplugging the charger. Thought that was odd at first - then I bought 2 x try batteries (not Samsung) and have since forgotten about it. With this post I am back to wonder why. Maybe because the batteries are after-market?
Sent from my SAMSUNG-SM-N900A using Tapatalk
anybody can help with this problem ???
Just ignore the message. Mine say to unplug charger as well....it's telling you that it's 100% charged and you can unplug it....meaning...unplug and GO..to work, school, friends house, best buy, and etc. Just ignore it.
Had mine OFF and charging all night long. Only thing I saw this AM was a battery icon with 100% on it. Means nothing probably I need to put it on charge while it is still powered up.
The charge ran down to 90-something % this am and I plugged in the charger. On for hour or so. When I looked it was fully charged but no obvious message. I have a battery minder app so I supposed that could sur press the message.
gautamsingww
