BELT CASE
ricks
82
I'm looking for a belt pouch(case) for my G5. Wanting one that will fit with a thin case in the phone. Anyone know of a good one? There's a bunch on ebay and Amazon but not sure which one to get...
You and I must be the only two people on the planet who use leather belt pouches!
I like the Cellet brand pouches. For anything not Apple or Sammy, you'll probably have to measure the outside dimensions of your phone /case, and look for a pouch with inside dimensions just slightly larger.
Nice.. love the trick questions.. by no means did you suggest any case constructed of leather as mentioned via your quote above.. thus I answered accordingly.
Yes, thank you. Now I need to figure out if I should get horizontal or vertical??? I can see the needs for getting both styles for certain days.
My biggest concern with these is finding ones where the phone will fit nicely and not be too loose or too tight.
I wonder if it smells in there??? LoL
I was thinking that the G5 is about the same size as the G4. Could help with more choices???
koltyn
