Best battery saving apps for S7 Edge?
G671
16
Just wondering if anyone is currently using (and is happy with) any particular battery saving apps on their S7 Edge? In my past experience (with other phones), I've found most of them to be useless. Just want to know if anyone is using anything that has actually shown significant improvement in their battery life.
All of them that I've seen are pretty much useless. Best thing to do is either turn off certain features or root your device
Greenify works well for me. I use it just for the Aggressive Doze feature. Without root, you can activate it using the adb command. With screen off, I drain 0.9%/hour.
Is Greenify (un-rooted) really any improvement over MM doze?
Greenify can make Doze activate in like 10min after setting the device down as opposed to 1hr like default MM. Also, it already has Doze to Go, a feature that will be available on Nougat.
Loki Samhain
