Best car mount
VRZNTHNDRBLT
I saw that Verizon makes one where when you plug in the Thunderbolt, it automatically brings up Google Maps and Media Player. Sounds pretty slick but comes with $39.99 price tag. Just wondering if anyone knows any other alternatives that does something similar besides just a regular mount, TIA :)
Reactions: Eclipse2K
First off - I do not know of another mount. And I bought the VZW mount and it is very particular as to where it is in the mount. It has to be completely down and locked in for the car dock to pop up. So I am kind of thinking it may not have many other docks that work quite as well. Not yet at least. But what I can suggest is find someone with a corporate account and can get accessories at a discount. I believe mine is 25%. Which can really make the difference when buying a $40+ item.
You also can't use a protective case with the vz car dock. I'm thinking about taking the dremel tool to mine so I don't have to keep removing my case.
the dock is only 29.99 and as far as i can tell it doesnt bring up the media player but i just use voice commands to bring music up
I like the verizon dock, but it kinda boher me that it shakes and vibrates A LOT.
I noticed the same thing. Tighten down the two knobs on on the mound bracket and one direct behind the phone cradle it helped with the shaking. My only gripe is that the micro usb connector on t he mount will not take my bluetooth headset... so I need to disconnect the cradle to charge my headset (or get a second charger).
Has anyone figured out how to customize the car panel screen? On my OD the car panel screen was fully customizable.
Anyone know if the 2750 mAh would fit with the car mount? If not, that'll be disappointing to have to switch before taking extended car rides.
Having to take the case on and off would be a pain. I am looking for a mount while using the gps feature.
JOLOVELY24
