Best Extended Battery?
DRILLINDK
18
The stock battery just isn't cutting it. Can anyone recommend an extended battery from a manufacturer they've had good experiences with?
Sent from my Nexus 7 using Tapatalk 4
There's a company called Zero Lemon that's coming out with a 10,000 mAh battery (more than 3X the current battery). I haven't had one from them but I can't find anything but good reviews on them. They are supposed to be avaliable by the end of October. They are also making a case to fit the larger size. Hope that helps.
I'm sure seidio will release one, I've bought tons from them over the years and have always been happy with the products.
Note 3 <Caesars>
Extended batteries will be available within the next month or so if it's anything like with the note 2.
Go with Zerolemon. I've had their extended batteries for my N2 and S4 and they are awesome.
Sent from my Galaxy Note 3
AyseDogan
