Best Launcher for S6 edge +?
italygrl1
72
Looking for a launcher to be able to customize a bit more..Can someone tell me whats the best one and uses the least amount of battery power??
Thanks in advance :)
I just installed Google now just until Samsung fix the freezing bug.
Long time Nova user but I tried Action Launcher a few days ago and it has some very nice features, will probably stay with it.
I keep coming back to TouchWiz, for reasons that some may find silly. I like its weather widget, I like its sorting options in the drawer, I like how thin it makes the Google search bar on the home screen, & I like the 3d parallax effect for wallpapers. For me, there are enough material designed themes available for it to also even like the icons that are available.
Technobuffalo just did a video on their top 3. I did pay for and use Action Launcher last year when I had the Turbo, so I can recommend it. I liked it, just not as much as stock.
https://youtu.be/6wkDkhD_qi4
I watched it and I still say stock. LOL
Yep...Nova for me as well. Tried Touch Whiz but it wouldn't let me put a widget on the toolbar, so went back to Nova.
Using Nova at the moment cause of the unread tags. Action 3 is really good too but diesnt have unread tags.
Posted via my SM-G928F
boone
