Best place to order scratched camera cover on Verizon note 4
p5200
197
I noticed the clear plastic has a scuff and a few scratches and would like to replace it. I found some youtubes showing how to do it I guess I should try to get an OEM part or, is there better options and where is the best place to order one? Thanks for all suggestions! :)
Ive repaired quiet a few note 4's. Safe to say the cheapest camera cover + glass lens,, i bought for £4.99 was exactly the same as the original. Dont exactly remember if it was a genuine oem item or a cheap one. But it was the cheapest one and was perfect fit. Takes about 5 mins to replace!
Do you need just the cover or the lens too? If you need just the cover then that one is fine! Just lift it up from the corner pry it up slowly and keep your finger on top of the lens so the lens does not lift up too.. just in case!
Well. I'm kind of confused I think all I need is just the plastic that's external that I can put my finger on so, I guess that's considered the cover and the metal rim that holds it in place? The camera does take pictures pretty well but, since that plastic part has scratches and and a scuff mark on it I might as well replace it with a new one just to make sure I'm not suffering any loss of picture quality. Thanks! :)
ericmark2002
