Best rom for signal strength?
jrsoit
22
I live in phoenix and ever since I got my gs3 back in September. I frequently get only 1-2 bars or im roaming. Is there a rom or radio combination that will or can increase the radio or signal strength?
Sent from my SPH-L710 using Xparent Green Tapatalk 2
Skunkape60
4,460
344
I would try one of the many different radios. Roms shouldn't make that big a difference.
jay28w
52
I would recommend the LJ7, then try LI3, then LG8. That's the last three radios, working backwards.
My 2 cents... I think my reception was better before I went to LJ7. Been meaning to do some playing around with prev versions, but have not had the opportunity yet.
jrsoit
22
I have lj7 and reception sux...gunna have to figure out now how to switch radio's. Is it just a kernal switch?
jrsoit
22
I flashed LI3 ill report back if reception is better the lj7 in the phoenix area at all. I downloaded all the radio's to try on the fly in the worst locations where I used to have service but with lj7 started to roam.
jay28w
52
Hey, jrsoit... any feedback so far?
Also, what should the process be when changing modems in terms of wiping or fixing permissions?
Skunkape60
4,460
344
Shouldn't have to do any wiping or fixing permissions. Just flash. Clark44 has a nice modem flasher which has all the modems included in a single flashable zip. When you flash the zip it gives you a list of modems to choose from.
Edit: just talked to Clark. The last modem he added was LI3. He said he would update it soon.
Here's the link...
http://forum.xda-developers.com/showthread.php?t=1816530
jay28w
52
Skunkape... Thanks for the info. Always appreciate your help.
So far I have about 6 hours on LI3, and thus far it seems to be a bit better than LJ7 in some of the areas of low signal strength. Will get a couple more days usage and post back.
jrsoit
22
So far ive had better service by 1 or 2 bars in the areas in Chandler and Tempe I was having issues with. LI3 seems to be a little better then LJ7 haven't tried other older radios yet. Battery life has been about the same if not better cause im not roaming in the places I was.
jrsoit
22
ronaldkaran
