Best Settings For CPU
XR88x
I was just wondering if anyone knows any good CPU configurations for this device. Currently, I have governor set to performance and I/O scheduler is set to default. I'm wondering if anyone here has a rooted device and has any suggestions for over clocking these devices. I am looking for just performance enhancement. I am using Antutu CPU Master Pro
You can also manually adjust the minimum and maximum clock speed to the desired performance. This way you know the device will always run at the minimum, which should be set on high. Note that you'll likely have battery drainage issues as the device will always be running at a high speed.
ahmadirsyah
