- Jul 19, 2010
- 31
- 0
- 0
Looking to pickup a battery wall charger for the droid x and a couple spare oem batteries.
Feedback is much appreciated.
Thanks,
Aaron
Thanks,
Aaron
I use the Moto extended battery, it seemed to do the trick for me, plus you have your oem battery as a backup... just charge it up. If you do get the moto extended battery it actually comes with a new battery door that fits better than the original would with the thicker battery. The door puts a small lip on the back, but that is better than squishing your components maybe causing screen problems.
As for batteries, the only thing I would suggest is OEM. The BH6X works great for me, but make sure you get it with a new door.
Using the stock door with the BH6X is a bad idea. It ends up putting too much stress on the screen, and causes the battery to heat up more than it normally would. In the last ten months I have heard of three people out of dozens upon dozens (gordol being the third) that made it work without any signs of screen distortion, but in most cases the door won?t even come close to fitting over the BH6X. I tried to make it work with my phone but I had to stop forcing it because physical damage was imminent. If it works for you already then consider yourself lucky, if you haven?t bought the BH6X yet then you should buy the one that comes with the proper back. It?s only a couple bucks more than the battery that comes by itself.
