Best way to start fresh on Android L?
Welcome to Android Central! Which device do you have? Usually, when I do a system update, I'll wipe the system cache partition afterwards. I would only do a full factory reset if the device was sluggish or otherwise still misbehaving afterwards.
I have a Nexus 5. One concern I'm trying to fix is my screen brightness fluctuates randomly with auto-brightness disabled. How would I wipe the cache? I'm not rooted.
Reboot into recovery and you'll find an option to wipe the cache. But a flickering screen is usually a hardware problem, not a software problem. It could be an LED that's going bad (the backlight for the screen is a panel of LEDs) or a loose connection.
Screen flicker is probably hardware. I have that issue too. Doesn't bother me. About half the time, I usually don't notice it.
devon9
