Best wireless charger?
katiheefner
116
What if your favorite wireless charger? I have the Duracell power mat but with my new case it won't charge. The samsung charger does work through the case but I want another one for work. I don't even think the case is that thick....it's a Kate Spade case from ATT if that makes a difference.
Samsung OEM wireless charging pad.
Posted via My Samsung Galaxy S6 Handheld Device
The CHOE Stadium Qi Wireless Charger has worked flawlessly for me.
I'm a fan of the Tylt Vu. But I agree, the oem wireless charger is above average.
And another vote for the CHOE Stadium. Works great, 3 coils means I can just set it down and forget it.
The Vu has issues charging with a case on. There is a weird way to get it to work that Tylt sent me a diagram for, but I wouldn't buy if I knew ahead of time about this issue.
I'm a fan of Ravpower's Qi chargers. Priced right on Amazon, soft touch rubberized finish and they work with my Tech 21 case on. They make a regular flat one and a stand one.
Posted via Gold 64GB Galaxy S6
i am using the Verizon stand one and it works flawless just set phone down and it charges no playing with a certain position and chares to 100% every time. I have only used my quick charger once to try it.
Second this. I use the stand one. Keeps phone charged to 100% over night.
I also use this. Works like a champ!
I'm also using this one. Works like a champ!
ive had great luck with pma mats in the past but these phones don't have a very strong magnet and depending on the case it may not work well.
Could you guys please post a link to the chargers you're talking about?
Thanks!
Sent From my Gold Platinum Galaxy S6 Edge
I ended up getting the original Samsung wireless pad, white.
I'm happy with it, but since I used to have the Palm Prē I actually miss how great the Prē and the TouchStone work together.
I've got the same one in white - can't fault it to be honest. It sits on my night stand, charges my phone while I sleep and in the morning it's at 100%
I have woken up a couple of times with it flashing blue and it not charging my phone - but only a couple.
Yea, I also keep it on my night stand, but so far it has worked flawlessly. Fingers crossed it keeps on working without a problem.
dayssss2
