Better Keyboard help
iggyb_hube
Active member
Mar 6, 2011
29
I have a HTC Wildfire and have downloaded and installed Better Keyoard. I went through the initial set up. The problem is that it is not been called when I do any typing i.e. SMS, Email, Notes etc.
What could be wrong and what may I have omitted?
iggyb_hube
Active member
Mar 6, 2011
29
BK enabled, high CPU usage??
Did you go to Settings > Language Keyboard and check your keyboard?
Thanks. Got sorted out. However at one stage I got a CPU warning with BK using 51% CPU. I have since disabled it again and reverted to the standard keyoard. Is there any reason why BK would use such high CPU?
rsbshshgdgdbxjdhd5775
