BIG comment problem
thatguy97
767
Over the past couple weeks, whenever I and several other users use the AC app you have to sign in EVERY TIME to comment. In fact it got so bad I sideloaded an old apk.
I want to let the right people know because this is a big issue.
Thank you
Does this problem persist on your side? I know we had some similar issues earlier this week. Let me know I can escalate things if still an issue.
There is no reply or comment button at the bottom of the screen anymore on my app. Why is that?
This might be the FAB behavior. If you're at the very bottom of the blog post, you have to scroll up a little bit. The floating action button goes away when scrolled all the way to the very bottom.
I can only reply back. Ive tried logging out im updated i cannot post new comments
Not sure which app you're using (main AC app or forums app), but try uninstalling/reinstalling and let me know if that fixes it. Have had one or two similar issues reported, and this seems to fix the problem.
Ac app i have to reply to a person in order to post.
@bsteppuhn - do me a favor... try logging out of the app and login again. Let me know if the problem persists. We did push some fixes awhile ago, so hoping a refresh will fix things up for ya. :)
