Bigger battery?
It's on back order, I'm waiting for others to get one and review it before I get it as well.
So its just a back-up not a larger battery? I hope its not any bigger had one for my og EVO and it got uncomfortable
We have a 1750mah, that one is listed as a 1900mah, so it will have more juice, but since i don't see anything about a new battery door, I'm guessing it should be roughly the same size...
Ye, it's pretty much a replacement battery, a little bigger than the original. Unless your battery is broken, then it's pointless to buy it just for better performance.
How much more time should one expect from a 150mah gain? I was expecting something much bigger in capacity for an extended battery.
I'm sure there'll be a 3500 one out soon, just gotta wait
but worth noting is that they're usually about 80 bucks
Platinum series is made my seidio, so it's a seidio battery
Yup. Seidio has it listed as not yet available. They have another, larger one on Seidio.com that has an unspecified storage capacity. The one listed and sold by best buy under the platinum name (seidio) is described as 10% more capacity.
I would wait and see the reviews for it. I do not know if i can stomache paying $50 for only about 10% more battery life rather then $80 for the 3200maH battery have have nearly double the battery life for only $30. Seems like a no brainer to me. But still, with the car dock i have, that wouldnt fit the 3200 one. So, guess i will wait and see what these do.
zeke
