- Sep 11, 2011
- 4
- 0
- 0
When you buy the Motorola car mount that Verizon sells for the Bionic, on page 3 it shows a Y-Cable that is not included...
Does this wire exist???
One end is a micro-usb, and the other end has a male USB and a male auxilary.
It allows you to plug only the one micro-USB into the back of the mount, and then it splits at the other end to plug into a car auxilary port and car charger; THIS IS EXACTLY WHAT I WANT TO DO!!! I was under the impression that the mount came with it. Mine did not.
Suggestions??
Suggestions??
