blank screen need data from phone, cant connect via usb cause of blank screen??
Danny Adams2
anyone please help me get data from invoicing from my fone, was set to sync to google via email, recorded all my times on timerecord pro, and now have blank screen no info for the month for billing.
Tried activesync, no luck wont connect
If anyone knows a solution i'd be very very greatfull
regards Dan
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,943
5,249
113
So are you saying your phone won't turn on at all, or do some things still function (e.g., does it still ring if someone calls you)? It sounds like you tried connecting it to your computer via USB--did anything pop up at all on the computer? If not, then the phone sounds dead. Do you remember if the battery was low? Try charging the phone for a good 24 hrs without disturbing it, then see if it will power on.
Danny Adams2
is turning on, windows brings up window with mobile partner(E), but of course there is only drivers etc links on that page, of no use, tried hisuite, and doesnt connect, updated to check, still same. battery charged, makes no sounds, have blank screen, so cannot select anything to connect via usb???? thanks fro responding, hope this helps you to find me an anwser regards Dan
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,943
5,249
113
I googled your phone and saw that it has TV output capability with an MHL adapter. Do you have one? It would be helpful to hook the phone up to a TV to see if something shows up. If so, then we can narrow the problem down to the phone's screen. If you're able to mirror the screen on the TV, you could also see if the touchscreen component still works, because then you could access the app you need. If the touchscreen is dead, then I'm not sure how you'll be able to recover you data apart from calling Huawei tech support.
saiid
