Blues Fan Well-known member Jun 21, 2015 4,705 100 48 Oct 10, 2015 #1 So I've been having Bluetooth on a lot since I bought the Gear 2s and I've notice that the battery has been draining faster. Is this typical? Has anyone else been having this problem?
athomas917 Well-known member May 27, 2013 230 29 28 Oct 10, 2015 #2 Yes, this is normal for all phones when using Bluetooth. You should have it off when not in actual use. Posted via the Android Central App
V vlfifthdawnlv Well-known member May 6, 2013 153 0 0 Oct 10, 2015 #3 Is bluetooth actually showing up on your battery usage? Modern bluetooth us very little battery. It should add up to less than 2% of your usage. A lot of times, its really just in your head.
