Bluetooth Connect Notification Sound
recDNA
8,784
161
63
Ever since the Pie update my phone dings whenever it connects to anything Bluetooth like my headphones, car and watch. It dings again as each disconnects
It is terribly annoying
I have system sound set to silent and manually shut off every category of system notification. I can find no Bluetooth notification sound to shut off? Has this happened to anyone?
Sorry - I found it. I had an app and a command both set to turn media volume to max when connected to my car. The beep was the annoying sound you get each time you press on the volume up button on the phone. Since it went to max the beep was quite loud. It also made the sound when my watch connected. Apparently it cannot tell the difference between bluetooth connections so it turned up the volume for all of them.
On the galaxy watch go to settings and hit "connection" and slide down to notifications and turn it off
ruhidubey0188
