Bluetooth Connectivity Issues, need help.
rchapman80
Active member
Sep 26, 2011
29
So I'm having a problem with my Samsung s9+ bluetooth. I have never had these issues before. I have a Frontier s3 and sometimes the Watch disconnects form the phone for no apparent reason. It will reconnect but it's frustrating. I also have a pair of Soundcore Liberty Lite bluetooth earbuds and the same thing happens. The podcast or music stops and then everything will reconnect and I have to press play again. 15-20 minutes later it again disconnects.
I have restarted all devices. I have disconnected and reconnected each device. I have hard reset the phone and that worked for about 5 days. The problem keeps coming back. I have the AT&T version of the s9+.
Any advice? Any help?
It sounds to me as if there's a problem with the BT in the phone. It's still under warranty, so bring it back where you got it and see if they'll replace it. (If it's too old for a new phone replacement, you'll at least get a refurb - it's still under warranty.)
Go to blue tooth control history .. click on
Mirrorlink .. Clear out cache + data ..
Soft reset ..
Rescan and connect again ..
See if it help ..?
I had some of that with my S9+ and AT&T.
after the Sept updates and update to Gear and App. I reset the Gear S3 and rebooted the phone several times. all working fine now.
Jayarealways
