Bluetooth controller not working with S10.
  • Start date Start date
A
Android Central Question
I recently upgraded to the Galaxy S10 from the S8. I have loved it so far... until this. I use retroarch, and have been able to connect a PS4 controller through bluetooth to play games. All well and good. When I paired the controller with my S10, it paired as an input device, but it isn't responding to any input. It doesn't matter what I do. I've tried using it on the phone and in Retroarch. I'm not sure if there is some setting between 8.0 and 9.0 that is messing things up, but it is definitely frustrating. Does anyone have any possible solutions? Thanks in advance. Any help would be amazing.
Having same issue. You can use it wired though. Just use the adapter that comes with the phone and your controller cable. Confirmed working on emulators I would assume any other compatible game as well. I will keep this question updated as I find out new things. I'm sure there are a lot of people going to have the same problem once the phone gets into its life cycle.
Exactly the same issue here. I have the S10e. I am able to pair and connect to the ps4 controller, however, The input doesn't work. Games also state that no gamepad detected.
This sucks! :(
sa1234
