Bluetooth device battery monitoring help sought.
xraiderv1
235
ok, given my preference for apps where I can pay to make any ads go byebye(one time for life payment thing)...
I'm looking for yet another app to monitor something.
in this instance, I need an app/widget that will allow for monitoring of my connected bluetooth devices.
such as my insignia bluetooth headphones, or my oontz angle 3 ultra bluetooth speaker.
both have battery capacities that mean I'll likely go days without a top up charge, and as a result haven't the first clue how much of a charge is in a given bluetooth device.
so, my fellow android enthusiasts, is there an app/widget that allows for this, WITHOUT my having to go through three menus...that I can just glance at and know?
reviews indicate it doesnt play well with the newer versions of android..what other recommendations do you have?
Ok, here's a native option: create a Settings widget for your Devices. Go through the steps of creating a Settings widget, and select Devices from the options. Tapping that widget will bring up your Bluetooth device list, and the battery level of any of the devices that are currently connected.
Bluetooth battery status shows in my quick settings panel on my Pixel 2xl (Android 10). It shows under the Bluetooth icon in that panel.
I also have a couple devices with companion apps from their manufacturer that show this in a notification in the notification shade.
my tablet(Samsung) doesnt do that with the quick settngs, and companion app? is there even one for the oontz angle 3 bluetooth speaker?
how do I do that?
Long-press any empty part of the homescreen and tap Widgets. Scroll down to Settings, then drag and drop it to the homescreen. It will then present you with a list of possible system settings for the widget -- select Devices.
settings does not appear to exist as a widget on android 10, on samsung galaxy tab a 8.0(2019)...not with nova launcher running in any event.
Hmm, strange -- it's always shown up for my devices regardless of the launcher I'm using. @mustang7757, can you check on one of your Samsung devices?
That's useful -- but still technically two taps to get there. A Settings widget would be one tap to get to that Bluetooth devices screen ...
Technically One tap after you pull the notification panel down slightly Screenshot_20200816-001231_Media%20and%20devices.jpeg
also..I would screenshot but the last time I tried screenshotting anything on a samsung, I spent two hours and gave up and just took a photo with my phone..
side note, pretty much the only real failing of samsung that I've ever encountered.
Just for my edification, can you show us the Widget list where Settings would be?
Ashok Dharshan
