Bluetooth issue?
adamm44
112
7
I've tried to connect my Incredible with my Flyer via Bluetooth. It always says paired but not connected. I know the Flyer is Bluetooth 3.0 and the Incredible is 2.1. 3.0 is backwards compatible with 2.1 though. Has anyone else had this issue?
Same issue with my EVO. Annoying, bit ill live with it until there's a fix. It's HTC, not Samsung. Samsung is horrible with updates
Sent from my HTC Flyer P512 using Tapatalk
Alright then. I figured I wasn't the only one with this issue. Hopefully it will be fixed with Honeycomb...whenever that comes.
I will let others guinea honeycomb for a while before I would download it. Honeycomb 3.1 is a piece of crap. I can name at least 15 major bugs. It made me ditch my SGT 10.1 for the flyer...I love the flyer, so I'm glad it was a pos.
Sent from my PC36100 using Tapatalk
I had the same issue, and asked HTC support about it. Here is their response:
>I understand you are trying to share files via USB between your HTC EVO 4G and Flyer. I know how handy it is to share media and I will be happy to assist. The paired but not connected message is normal since we haven't asked the two devices to push anything yet. Try opening up your Gallery (or other application depending on the file you wish to push) and select to share a file via Bluetooth and see if you can push the file. The two devices should then connect.<
(They say "USB", but my question was about Bluetooth, and the solution works).
I must add that it was a very quick response, too. I was very impressed. I know this is an old post, but I didn't see that anyone had found a fix for the problem.
çhimezie
