Bluetooth phone call problems
mrtonk
350
22
I have a Motorola Rockr T505 Bluetooth device for my car. When I first got the Bolt, it paired perfectly and played music and did phone calls. After the first time I did a factory reset, however, I was no longer able to make phone calls using Bluetooth. I have since reset again, and the problem persists. I looked for a place to select that I wanted to use BT with the Bolt when BT device is connected, but I could not find this option. I am now running the MR2 radio and the problem persists. Anyone else ever have a similar problem and have a solution?
They are paired and I can play music but not make phone calls. Never seen this before.
Reactions: mrtonk
Not sure if this will help you but I came across it and figured I'd post it for you. I don't use Bluetooth to play media so I'm not sure of the options that are available but you may want to check the settings on your phone and bluetooth device to see if you have an option to turn on/off media or calls.
http://forum.androidcentral.com/htc-evo-4g/18845-disable-bluetooth-media-but-not-phone-calls.html
THANKS! This worked - "Phone" was checked already, but I unchecked it and then re-checked it, and it is working properly now. :-)
