Bluetooth power drain
uw
129
Anybody else have a bluetooth power drain issue? Everything about Mate 9 is great, but I do have this issue with the bluetooth draining my battery. I would turn on the bluetooth to use it with my earphone. After I'm done, I would turn off the earphone and turn off bluetooth, but then I notice that my battery would drain like crazy. Only thing that helps is if I restart the phone. Any suggestions or am I doom to do a factory reset?
I m using a Sony sbh70 with my mate , no battery drain here .
Im keeping the Bluetooth connect all day.
Does Bluetooth show up as a big battery user in the Settings>Battery menu, even if you're turning it off when not in use? If so, go to Settings>Location​, tap Menu>Scanning, and make sure Bluetooth Scanning is turned off. It might also be in Improve Location Accuracy.
Yes. The bluetooth shows up in the consumption level. Ok, I turned off the bluetooth scanning. Hope that works.
rosannejoy555
