Bluetooth Problem
DaveW#AC
8
I can't get my bluetooth headphones to work with my NC. I'm using the CM7/CM9 dual boot on a 16gig sd.
Bluetooth will turn on, pair, and connect. As soon as I load an app and sound commences, it will disconnect. It works fine with no problem on my cell phone or iPad.
Bluetooth was never meant to be used and is not enabled in the stock firmware. Your Bluetooth quailty depends on how well it was made in the factory just like the Max CPU clock speed it just depends on your Nook.
Sent from my NookColor using Tapatalk
ChrisAndroid
