Bluetooth Problem
Jan 24, 2015
12
I can't connect to another Bluetooth device. i tried all possible settings (turn on, visibility ,distance) nothing change
First, make the device discoverable. (See the device's manual to find out how.) Then scan in Bluetooth on the phone. When the phone finds the device, let it pair. Then - if the phone can use that type of Bluetooth device - it will connect to it.
You probably can't use a Bluetooth printer (I don't know - I don't have one to try). You should be able to connect headsets, earphones, etc. - music and handsfree devices - and you should be able to connect to another phone or a computer to transfer files.
heritagevines37
