Bluetooth problems
ace0187420
129
Anyone else having Bluetooth cut in and out when the Wi-Fi is on?
Sent from my rezound using Tapatalk 2
Since the ICS update, I've had periodic problems with Bluetooth cutting out while I'm on Wifi. Happens maybe 70% of the time and I've not been able to figure out why it starts, the only thing that cures it is a reboot. Never had the problem with the same phone and headset before the upgrade. Very frustrating.
I find my self having to turn off bt, turn off the head set, reboot, then turn on bt and the headset. Grrr. Hoping that the update fixes this. Im also experiencing horrible battery life, but want to try one or two more things before I either start a thread or ask for a new unit. I think there is a case of poor manufacturing where some units have crappy life. I've run into this in prior phones that were replaced.
This was happening to me the other night but I was on 4g / 3g. I thought it was Pandora but it happened even when playing mp3 files stored on my phone. This was never a regular problem for me even after ICS.
Sent from my ADR6425LVW using Tapatalk 2
Ever since the ICS update I've had bluetooth issues regardless of whether wifi is on or not. BT was rock solid on GB, so unless my hardware went bad, I'm pretty certain it's a software issue. I have to constantly reboot my phone as my BT gets stuck - refuses to turn on, even when on, can't get to BT settings as it crashes with an error. Those are my main problems and it's quite frustrating. Happy with the phone, but really hoping this gets fixed really soon. I can't stand rebooting my phone several times a day. Getting to be unacceptable if you ask me.
FWIW, my Bluetooth works fine. I am on the global RUU and stream audio to a Phillips Fidelio all day.
I ran the global ruu and my blutooth works good again.
