Bluetooth streaming with data in car on JB roms
kca2000
696
147
I'm looking for feedback from anyone that streams bluetooth in their car.
On AOKP ICS i never had an issue with the Metadata showing up on the cars screen. I assume that was because AVRCP 1.3 was included in those builds.
My question is, is anyone having luck with the metadata showing up in their car while using bluetooth? If so what kind of car is it and what ROM have you had it work with?
I don't currently drive a car with bluetooth streaming, but i would like to know what ROMs have this working for future reference. It did not show up in my friends Buick, but with ICS builds it did. Any feedback would be helpful, or if anyone knows of JB builds with AVRCP that would work as well.
Thanks in advance. :D
I had a problem with it working in my 2012 Mazda3 when I was stock. I am on AOKP 4.1.1 Build 1, and metadata works without a problem.
I will say though, I did have a problem with the playback of my music, there was some choppyness (sp?) and some static. I cant figure out what the problem is though, or what the cause is. Needs more investigation.
Reactions: kca2000
No metadata on my 2009 Ford Edge with Microsoft Sync. I get metadata on my iPod but not on Bluetooth.
What Rom are you running? I assume when using your ipod your using a cable made specifically for it correct?
I'm currently running CNA. But I've tried it with Skank CM10 and AOKP also. No metadata with any of them. I think it might be a limitation for my version of Sync.
For my iPod, I connect to Sync via USB using the normal iPod charging cable.
Reactions: kca2000
958ryan
