Bluetooth Syncing w/ Car Issue...
mthompson8
Active member
Jun 8, 2012
27
Anyone else having a problem with the bluetooth on this phone? here is my deal. My car has bluetooth capabilities via phone, and also music. it is great. listen to my playlists from my phone in my car and if i get a call just hit a button and start talking. my previous phone was the evo, and i never had any issues with this. Now with the S3 i am constantly battling my phone to stay connected. I have tried playing with the settings to use it for audio and media, but i can't seem to be connected using both. for example, if i want to listen to music, it will stream through my car, but while that is playing, if i get a call, the call won't be picked up through blue tooth and vice versa. sorry for rambling, but does anyone else have this problem?
My S3 is working fine with my 2008 Ford Sync. When a call comes in, the audio (music or podcast) thatis playing stops and I talk. When I hang up, the audio starts again.
You might want to check with your car maker to see if they have a fix or reset the phone.
Good luck!
I had the same problem..this worked for me..power down phone..then remove battery for 1 minute..and power back up..let me know if this works
sent from my galaxy siii via Tapatalk ii
shy_panther
