My sister recently gave me an Evo to fix for her that her boyfriend tried to "root" (have no idea what he did) and I'm haveing a tough time. When turned on the phone hangs at the white HTC screen and stays there requiring a battery pull. Once you pull that battery the only way to get it to even do that again is to leave that battery out for about 20 min and try again. If you try to turn it on before that nothing happens except for a dim red light turning on near the notification light. I am able to boot into the hboot but trying to go from there into recovery just hangs it again at the white HTC screen. I tried going to the usb setting and using htc sync to repair it with a stock image and it wont recognize the phone even though when connected the computer registers it as in the usb as an android 1.0 device. I also tried putting an image on the root of an sd and renaming it pc36img as i read in another forum this looked the most promising as it started to read the zip and got to where it said parsing file and stayed there for a few hours. Finally i ended up doing a battery pull and now if I go into hboot with the card in it freezes at the screen with the skateboarding android with out the card hboot works normally. Any help would be appreciated trying to save my sis from having to buy a new phone.
