build.prop values
cpshelley2
128
8
i was curious if anyone knew the functionality of some of these build.prop options:
ro.ril.def.preferred.network
ro.telephony.default_network
persist.service.mount.playsnd
ro.ril.def.agps.mode
persist.sys.use_dithering
ro.compcache.default
ro.mot.eri.losalert.delay
dalvik.vm.lockprof.threshold
keyguard.no_require_sim
i found these values in the aospCMod zip, and they are not in my build.prop -- just wondered what they do, and if it would be worthwhile to import any of these to my build.prop file.
ro.telephony.default_network is normally set to 4 which enables auto-switching between CDMA 1x and EVDO data modes depending on availability. 5 is 1x only, 6 is EVDO only, 7 is auto-switch GSM/1x/EVDO but we don't have that. :(
So, leave that one at 4.
BNIDirect terkunci
