Cable to connect Note 3 & Note 10.1?
Jon234567890
5
Hi all,
I am looking to be able to connect my Note 3 and Note 10.1 2014 together via a Cable instead of Bluetooth, however I cannot find a Cable with the correct Plugs, I already have a USB Cable for the Note 10.1 2014, but I then have to use a second Cable from the Note 3 to connect to the Note 10.1 2014 Cable.
Can you get a Cable with two Plug (male) ends to connect to the two (female) ports of the Note 3 and Note 10.1 2014? Or must I use two Cables?
the Samsung Note 10.1 2014 uses a Micro type B USB Plug,
http://images.mobilefun.co.uk/graphics/misc/29425-2.jpg
but the Samsung Note 3 uses a different Plug, a Micro type B USB 3,
https://upload.wikimedia.org/wikipe...p_.jpg/651px-Connector_USB_3_IMGP6033_wp_.jpg
Jon
Hi,
to Tether the Note 10.1 to the Note 3, so that I can go online with the Note 10.1 - only the Note 3 has 3G not my Note 10.1.
The Note 10.1 has a much larger screen and much easier to read and work from.
Jon
Just set up a wifi hotspot on your note 3 and then connect your 10.1 to the hotspot or get a micro usb to female usb adapter for the 10.1, then you can use your note 3 cable to connect.
Hi, thanks,
but does Samsung, or an accessory provider, not provide just one cable instead of connecting two cables together, you would have thought that they, or some other company, would have, after all they have manufactured two devices which are advertised as being able to Tether and be Tethered, but yet not actually provide a single cable for it?
Jon
No need for cables. This isn't 2002. Set up the wireless Hotspot on the Note 3, and your Note 10.1 can get on the Internet through it without cables by using wifi
Hi there
Bluetooth can potentially be a security risk, of course security precautions should be taken such as turning Bluetooth off when not in use, etc. but by using a Cable as a matter of routine, especially in public places, or in business negotiations... Bluetooth security issues can be overcome - by not using it, and Tethering directly using a Cable; especially important when the onus is on the user of the mobile equipment, not the company he is working for, even if the equipment was provided for by the same company, a bit unfair I think, but that's the way it is.
Oh well, two Cables it is then!
Thanks
Jon
Hi there
Thanks
Jon
Am I in the Twilight zone here? I never said blue tooth. I said wifi, which can be set up securely.
Hi there
Thanks
Jon
Misterb is suggesting a secured wifi hotspot from your phone. I do this all the time in public places. It's far less cumbersome than using a wired connection.
If you're running the hotspot for a long time, you can even charge your phone while it's acting as the hotspot.
Sent from my SM-P600 using Tapatalk 4
Question: What app do you use that addresses the tetheriing ports where both ends are Android? Most wired tethering is PC/Android not Android/Android.
No app required. When you plug in it automatically tethers the 10.1 to the N3, or you can toggle it in settings.
I wonder if this requires the cable to be OTG or not (the pin setup is the same but the "Sense" terminal is grounded on OTG while 'floating' on a normal cable). Mmmmhhh...
