Cable
gdruin74
Active member
Oct 2, 2013
28
Is there a special cable needed for the pioneer head units or does it use a regular cable?
For Android Auto? You just need a USB cable, like the one you use for charging and syncing your phone.
Have not had installed yet. The guy at the store was saying that I need a special cable for Android auto to work. For $100.00. Didn't think that was correct.
Absolutely not correct. Any normal data cable — not power-only — should work just fine.
Just make sure they run it from USB2. (USB1 is for Apple CarPlay.)
kiki2025
