R red rage Well-known member May 5, 2010 46 0 0 Sep 10, 2010 #1 Since froyo 2.2 calendar does not give alerts. any ideas
mclarryjr Retired Moderator Nov 2, 2009 5,580 950 113 Sep 10, 2010 #2 After you have entered your event in the calendar before you hit save just hit menu then select add reminder
A allthem New member Jul 30, 2010 4 0 0 Sep 12, 2010 #3 I had the same problem, i had to do a factory reset to get it to work again.
J jayhawkfan18 A Dude May 14, 2010 416 13 0 Oct 22, 2010 #4 I don't seem to be getting any alerts either... any other options besides a factory reset??!
mclarryjr Retired Moderator Nov 2, 2009 5,580 950 113 Oct 22, 2010 #5 You could try clearing your data and cache in the calendar app.
