Calendar Help
Priscilla Johnson
Active member
Nov 19, 2012
41
I have a Samsung Skyrocket and Nexus 7 (2013) that have 2 different calendars. I have not installed another calendar to either device, but the calendars are different and don't update each other. Is there a way to get the Skyrocket Calendar on the Nexus 7? I believe the Nexus 7 uses the Google Calendar, but I'm not sure what calendar the Skyrocket uses. I have checked my App store and it is not using the Google calendar but I can't find the name of the calendar it does use.
Thanks for your help in advance.
my guess is that the Skyrocket Calendar App has a setting for which calendars you'd like it to use - "internal" or "cloud". it would seem that you have it set to use its own internal Calendar that's simply a database that resides on the phone - and NOT a "cloud" calendar like Google, Yahoo, Microsoft, etc. that resides in the cloud on the internet. if you want your calendar synced across all devices - you need to use a "cloud" calendar like Google.
good luck.
p.s. check out Jorte -
https://forums.androidcentral.com/e...id=jp.co.johospace.jorte&hl=en&token=94JVC4mQ
ameliadinkins
