Camera click sound.
raju130000
111
A friend of mine has a Verizon N2 and somehow his camera click sound is off. But I can't seem to figure out how to do it on my sprint N2. The phones are the same so we should have an option. Has anybody figured out how to turn off the click noise when taking a picture?
Sent from my SPH-L900 using Android Central Forums
You can find in the settings and in the camera options. Select the option to turnoff click sound while taking picture.
I just deleted the noise sounds from the system. If you want them for later, you can just move them to a different folder on a sd card. I believe you have to be rooted to do this though. There are 2 for the video recorder and 2 for the camera (actually I believe there is 4 but I think you only need to delete 2 of them).
If you are rooted, use root explorer (I'm sure other file explorers will work too, but I know I couldn't find them with ES File Explorer) and go:
system > media > audio > ui
the files I deleted are:
camera_click.ogg
Camera_click_short.ogg
Shutter
Shutter multiple
and for the video recorder, I deleted:
cam start
cam stop
again, I don't think you need to delete them, just in case you want to put them back, just move them to another folder (might have to be on an external sd)... but I deleted them and have had no problems
The Verizon, T-Mobile and AT&T versions have a shutter sound toggle in the camera settings...not the Sprint version.
The Verizon and AT&T versions have a shutter sound toggle in the camera settings...not the Sprint version.
Why doesn't the sprint version have that? Where in the att and Verizon version can you do it?
Sent from the Beast that is Galaxy Note 2
Iirc, the photon was the first to leave that out... I guess it's so I can't sneakily take naked pics of my fiancee while she's sleeping...
On a serious note, it doesn't bother me at all so I'm leaving it in.
Sent from my SPH-L900 using Tapatalk 2
You also can't take pictures of babies, kids or pets without disturbing them and losing a picture moment. Sure, you can get 1 shot, but that's it. Also, why would anyone really want to try to be quiet about taking pictures during quiet moments like school plays and whatnot.
Exactly! There are many reasons, this is a bad move.
I wonder if the stream surrender I had on my photon will work...
Sent from my G-Note 2
It is also against the law in some places to not have the shutter sound to prevent those candid pics.
That being said, just rename the files above no new to move them.
Whatever the file name is. Ogg. Bak....... will do the trick. Damn auto correct but you get the point
Sent from the nexus of the Android world, the SGS3.
I have the TMobile Note 2 and under settings while in the camera there is a toggle to shut off the shutter sound. Its down near the bottom of the list as shown.
Sent from my SGH-T889 using Android Central Forums
After Diordna11 post it's official only sprint doesn't have the shuttle sound. Is there official samsung forum where we can all complaint so they put it in the next update?
odigon
